NEED HELP FINDING THE FUEL PUMP RLAY 87 GT
RE: NEED HELP FINDING THE FUEL PUMP RLAY 87 GT
open your hatch facing the front of the car, down to your left take the pannel covering the tail light off their should be a little black box with a white pice of plastic stick out of the top push it down it should click and then try starting it again, also it could be a little round orange button that you can push to, its one or the other
That is the inertia switch, it is like a circuit breaker. It opens the circuit if you get hit in the back. The actual fuel pump relay is under the drivers seat I believe.
