Fuel pressure help
RE: Fuel pressure help
[/quote]
2 regulators??? you do know that the holley regulators have two outlet ports right?? the second regulator is unnecessary ...ALL YOU NEED TO DO IS RUN THE the 2nd outlet port to the fuel selonoid and when running NO2 just bump the pressure to overall system up to 6.5 psi depending on shot running..I too am running the superpower shot system and I run 6.25 psi with the 100 shot nd no probs yet doing it the way I mentioned and I can monitor fuel pressure and bottle pressure on every run out my windshieldbtw your motor looks good!!
http://i242.photobucket.com/albums/f...inished002.jpg
http://i242.photobucket.com/albums/f...install005.jpg
[/quote]
I am using both ports on the 1st regulator to the carb.It is HIGHLY recommend that you run 2 seperate regulators with Nitrous.
mrappe
09-26-2015 10:16 AM
