installed intake spacer and egr pipe is too short
I replaced the GT intake with a ported cobra as well as a 3/8" spacer. When I started to boltthe upper up I realized that the return pipe between the EGR vavle is now too short and preventing me from bolting it back up. Is there an easy replacement for this or do you have to make your own?
thanks in advance...
RE: installed intake spacer and egr pipe is too short
SN-95??
if so...
http://store.summitracing.com/partde...p;autoview=sku
you will need to shorten the EGR tube slightly for this to work
if so...
ORIGINAL: mjr46
I have just found the appropriate size tubing before and added length needed via weld it in
^^^^^yes but that requires time I just walk over to my metal bin pull a piece out and done in 5 min but for the at home do it yourselfer..your methood is a good idea
^^^^^believe me I know what you mean!!! if I had a quarter for everytime I had to pull the mig welder out to tack something I'd be rich
x2. It would be great to weld one myself but that is not an option for me.
ORIGINAL: AdderMk2
If i had a welder.... MANY of the problems that I have run into with this damn car, wouldnt be such a big deal
