clutch adjustment?
clutch adjustment?
Hey guys need some help, im kind of dumb when it comes to clutch adjustment . I have a fire wall adjuster, and was wondering if i make the adjuster longer or shorter to make the clutch grab lower?
also all of a sudden my rear end is leaking???? i just had it rebuilt about 1 year ago with 31 splin axles, 4.30 gears, aubern posi, trick flow cover , all new seals and bearings>>???? anythoughts?
RE: clutch adjustment?
ORIGINAL: PRO50SC
You need to add slack to the cable (longer) to grab lower and as far as your rear, have you looked to see where it's leaking?
ORIGINAL: greenstreak9205
i think he meant where from the rear end is it leaking....the rear cover, at the axle ends, from the middle of the tubes
ORIGINAL: kweb288
by adding slack to make it longer, do you mean unscrew the fire wall adjuster so it sticks out further?
junior04
09-28-2015 10:53 AM
