intake gasket
intake gasket
Well antifreeze was getting into my intake cause the exhaust was shooting white misty smoke so im resealing the intake manifold, so im guessing im gunna have to order one from holley bc i doubt the parts store will have gaskets for an aftermarkey manifold? The gasket for the lower manifold is the same but for the upper is diff....
RE: intake gasket
ORIGINAL: 5pointslow91
RE: intake gasket
antifreeze was in the oil wen i drained it, i stopped running it so it wouldnt do nemore damage, it did this b4 and wen i resealed the lower intake manifold it was fine again
RE: intake gasket
make sure you get all the crap flushed out of the oil and if it keeps doing this as you said it has done it before I'd make sure the surfaces aren't warped or it's torqued down properly
RE: intake gasket
it was torqued down properly last time but i think the prob was wen i went to put the lower manifold back on, it moved the gasket cause the sealer wasnt dry yet, so this time ima put the sealer down and then the gasket and let that dry a day or 2 b4 i put the manifold back on, was in a rush last time and that doesnt mix with mechanics
daltron
04-28-2016 08:10 PM
