most help is appreciated 95 5.0 misfiring
ok so I have a 95 5.0, everything was fine and then it started misfiring. I replaced the cap, rotor, coil, plug, wires and air filter and then the problem was still there. It's like an erratic misfire while driving not to mention there is no power and the car shakes violently while driving. I got a fuel filter that i'm going to replace, but I dnt know what is going on. The problem was consistent before and after the tuneup then all of a sudden it has gotten much much worse. Thanks guys if you can help me out..
RE: most help is appreciated 95 5.0 misfiring
Replace that fuel filter, maybe it is so cloged that when you give it gas the fuel is not getting to the injectors because of the filter. You have it so put it on and then go from there.
I replaced the fuel filter and still the same issue. The other one had some discolored fuel that came out of it when I blew through it, but the fuel seems to be clear thats coming from the new one.
You may need a new throttle position sensor than would explain a rpm jump. easy to change it is located right on the throttle body and held on with 2 screws. It should cost about 80 bucks give or take. only other thing that comes to my mind is a ignition module going bad. But sunce you got that tps code I would start out with changing the tps.
