could be i would look at my stock mount in my 91 though i tossed it in the garbage. i would just go an order atleast a new stock set of mounts probably like 30-40 bucks or poly;s 150 ish and solid cheaper.
i heard that solid engine mounts arent to bad with a poly tranny mount, its a weekend warrior and a drag car for the track. any suggestions on solid mounts ?
are there slide holes on the K member or something. if you compare the driver side to the pass side the mounts look way diff. can you maybe slide on side up and the other side down to even it out?
