smog pump
smog pump
can some one point me in the direction of removing the smog pump and plugging it. i already bypassed it like a year ago and i wanna take it off completely is there some very detailed directions floating around somewhere..i looked can find anything...
thank you
thank you
RE: smog pump
Cut the steel line where it connects to your midpipe (leave an inch or so and plug it) Then make another cut to the steel line near headers(this allow you to pull the entire steel line out when you remove the 2 bolts holding steel line to the back of the heads).Get a 84.5" belt and some small black vaccum caps for the straw like vac lines.
jwog666
12-27-2021 08:09 PM
mrappe
09-26-2015 10:16 AM
