Getting Codes 12 & 22 on koeo test?
Getting codes 12, 22 on theKoeo test. MAP sensor out of range. At startup, it wants to die when at operating temp(idle dips to 400rmp's) Starts perfect cold.
RE: Getting Codes 12 & 67 on koeo test?
From that list..... looks like you have codes 67 - separator(1) - 11 (system pass).....code 12 is not a valid KOEO code....... code 67 is not a problem since you were able to run a KOER...... code 67 may have been logged if the transmission was not in-neutral and the KOEO was run. Codes 44 & 94 are normal, or the equivalent to a system pass due to emission parts delete you did.
RE: Getting Codes 12 & 22 on koeo test?
ORIGINAL: Joel5.0
ORIGINAL: Joel5.0
If the codes output is....... /-/-/-/-/-//-//-//-// .....11 - separator - 22.... clear codes (disconnect battery for 15 min.) and rerun KOEO.
Make sure the vacuum hose to the MAP is not collapsing or has a vacuum leak.... also make sure the intake port the MAP hose goes connected to, is not clogged. Suggest to do a Base Idle Reset Procedure after you clean the TB with carb cleaner and a nylon brush. LUK
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
