Explorer MAF/Injectors
RE: Explorer MAF/Injectors
ORIGINAL: mxrider426
Thanks that helps alot! Do you know if i can use a truck MAF or a super coupe one?
but i'd say to get a new maf like a c&l thats calibrated for the 24's just pull the sensor off the top of your current one and throw it in the new housing. it's not the actual sensor that effects it, it's the ammount of air it samples in an aftermarket maf. so if you ever wanted to change the injectors you buy a $20 tube to bolt in that c&l housing
ORIGINAL: uenvyboykin
i would recomend getting your injectors new, especially while running a power adder. just my 2 cents
clean out some from a junker and throw 'em in and they'll be fine
ya agreed you would probably be fine, just would suck for 1 of those to not flow right, the car to lean out, and 5-6 grand down the tube...
im one of those safe then sorry guys after a few mistakes i made that cost me some money, but in retospect a new injector could fail too
if u are using used injectors it would be best to spend the few bucks to have them flow tested at a shop it only cost me like 12 bucks 2 years ago and a rebuilt kit for them is only 20 bucks so save yourself a future problem/headache.
waid302
09-14-2015 11:19 AM
