So my oil light has come on 2 times in the past month each time it was because my oil was pitch black. I changed my oil filter each time and now it came on again today. whats makin my oil so dirty? how can i fix it? thanks
If you're running rich, that would contribute to carbon build up in the engine, thus your excessively darkened oil. Excessive piston ring blow by from a worn engine as someone else pointed out here could be the cause as well. The gunk from the oil could be pluggin the sensor for your oil pressure which is tripping the light. What weight of oil and how often do you change it?
