converter good?
converter good?
my aod transmission burntup (fluids leaked and it was driven for 10mins ) anyway i was woundering ifmy 2400 stall converter is still good or not. i pulledthe tranny out today and the fluids smelt burnt. the tranny kept slipping and wouldn't stay in gear.
RE: converter good?
i think the aod has a lockup converter, if thatsthe caseyou should replace it. the clutch inside is most likely damaged. if its non lockup, take it to a good trans shop and they should have a machine that can flush it out.
RE: converter good?
hard to say, but when rebuilding transmissions they say to never use a lock up converter from a trans that has burnt up, they cant be flushed and will hold debris that will enter your new trans and most likely cause it to fail again
Faolan65
08-27-2015 06:40 AM
Faolan65
Arizona Regional Chapter
08-25-2015 09:24 AM
