Help! Won't start
92 GT 5.0-EFI,EEC-IV System,38LBS fuel pressure,coil good,new cap ,new rotor,good plugs good spark to plugs,new ign module,new crank position sensor, fuel injectors not pulsing. Did test injector harness with light node.
RE: Help! Won't start
My 94 Gt 5.0 was going through a spell where it would not pulse the injectors. I had a guy from a Ford Dealership look at the car and he said it was either the ground wires by the battery or the ecu was going bad. I took off the ground wires and cleaned them and I still had the same problem. I'm in the process of changing the ecu with a new one. If you have not also seen this thread check it out as well about a car not starting. Hope this helps.
http://sbftech.com/index.php/topic,588.0.html |
Thanks for the reply... pony was runnin great,pulled into the store to get an icee and then wouldn't fire....all at once....first thought was computer but then second guessed myself and it's been a escapade ever since....
| All times are GMT -5. The time now is 11:52 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
