need some help with fuel pump...
I just installed a high flow perfomance fuel pump in my 1990 mustang gt and every once in a while when i hit the gas my car will bog down and not really pick up any speed then i simply let off the gas and stab it again and by the second or third time it's going fine. sometimes this will happen once a week or 5 times a day but only after i installed this bigger pump. do i need to put in bigger fuel inectors? can i install bigger injectors without changing maf and computer?
RE: need some help with fuel pump...
Well if it's doing since the install, I would suspect either the pump or your workmanship. You can't install bigger injectors w/o changing/recalibrating the mass air.
mrappe
09-26-2015 10:16 AM
