Valve cover gaskets...is sealant needed?
gonna have the intake off, so I figured I change these while im in there.
RE: Valve cover gaskets...is sealant needed?
I got some metal rubber ones,there awesome! no sealant needed and can be reused
Thanks primetime.
i am running the same metal inside and rubber coated and reuseable and only like 20 bucks
yep, same here... felpro rubber w/metal core...
Ive had my v/c's off so many times in the last few months, and still not one leak |
I always use just a dab of 3m yellow glue to hold it on the valve cover.
yeah, the blue rubber ones with the metal insert are awesome, I had a set last me a couple years til I lost one when i had my motor apart.
reuseable as many times as you want and they seal it up good. |
same as everyone above...but depends on the ones you got.. if they are cork. I always use a little sealant
