just finished the hci today, need help
RE: just finished the hci today, need help
24's. when i listen next to the driver side valve cover there is a clapping noise, kinda like an exhaust leak. i haven't plugged off the pipe that comes off theexhaust so i know there is leaking. i tried backing out of the driveway and it struggled to go up the little incline. i decided to pull it back in the driveway. i have a sound clip i just never done one before so it might take a few mins to post it
RE: just finished the hci today, need help, sound clip added
1- check gap on plugs
2- individually pull a wire off the cap and see if idle quality changes at all or if its sparking, for example if you pull cyl 2 off the cap and hold it close to the cap you will see the spark arcing from the cap to the inside of the wire.
3- my nieghbor did this one to my car, take a lead tip point with a wire and ground it to the negative side of hte battery, and individually stab each boot of hte wire on the cap, idle quality will change when you stab the problem cyl.
4- check vac. my car pulls 19ish lbs at idle but i am SD and you sound like your MA
I bought injectors off ebay and when I did my hci it ddint run right I couldnt figure it out turned out to be a plugged injector gotta love ebay injectors!!!
KingRando
10-02-2015 08:06 AM
mungodrums
09-28-2015 10:54 PM
