Intake questions for 93 and older
I got a BBK ssi race series intake and it should fit up to a 93 5.0. Well I'm putting it on a 94 5.0. My questions are:
1. What is the part number for the little screen in the bottom of the PVC hole? Here is a pic: http://i324.photobucket.com/albums/k...z/IMG_0119.jpg
2.There are 3 threaded ports on the new intake that are blocked off on my old one. What were they originaly for? vacum ports? They are circled in the pics below.
http://i324.photobucket.com/albums/k...20modified.jpg
http://i324.photobucket.com/albums/k...21modified.jpg
3. for the fuel injectors is there any lube I can use on teh o-rings on it? WD40? vasline?
RE: Intake questions for 93 and older
a little grease or vaseline will work for o-rings and the two ports at the rear are for extra coolant sensors most likely..just plug them off and the one single one.....for a fox it looks like it is the area for an air charge temp sensor..sn-95 won't have it there I believe
Hmm K thanks Ill use on of those ports for a extra coolant guage than and plug off the other 2. I'll use vasline to lube the o-rings for the injectors as well. I'll go to a the ford dealer and order the screen, seeing i'm gonna go there to get 2 new coolant sensors for it also. Thanks for the help
I use oil for my injectors. pic one is for the Intake air temperature sensor, and in pic 2 those can be plugged, or you can use those to add an aftermarket temperature gauge.
Luke9222
10-22-2015 11:55 PM
