injectors i should get
RE: injectors i should get
a supercharger profides boost or forced air induction, upping the boost would be more psi... you are at 6 which is low, he is saying if you up the boost, u will need more fuel...
if you need more fuel you will need to rebuy injectors and have your mass air meter tuned for that size injector which both of those could easily cost you around 4-5 hundred, long story short try to only make the purchase of injectors and mass air once
