Bearing size?
Bearing size?
Ok, I just rebuilt my 302 and had an oil pressure problem. So I tore it back apart and think my main bearings are suspect. Crank was ground .010 under to 2.240. Used clevite 77 "p" .010. I have a bit too much clearance between the crank and bearings. Plastigage says less than .003 clearance. Which makes sense because: the original bearings measure .096 thick, and the clevites measure .101. If they're supposed to be ".010" over, my math says they should be closer to .106? That would fit about perfect. I've tried two sets, both measure .101" I'm going to pull out the crank and re-check the crank bore in the block. I hope I don't find out of round mains. But either way, whats up with the bearings? they should be .010 over size, not .005 right? Anybody have any Ideas??? Thanks everybody!
RE: Bearing size?
I know the crank is .010 under, I'm wondering about the bearings. Also, I should mention that I triple checked the crank gind and come up with 2.240 the factory grind is 2.249-2.2482 which means my grind is actually on the high side.
Offendant
09-23-2015 07:21 PM
ccdguy
09-19-2015 05:20 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
