oil pump??
RE: oil pump??
Why do you think that the pump is bad, engine noisy?? Or just reading low on your gauge. Mine was reading low and I replaced the sending unit, after verifiying that the oil psi was good with a mechanicalone,and the gauge is reading correctly now.
RE: oil pump??
engine comes out the top and motor can be jacked up with mounts undone ..drop pan down enough to reach in and undo pick up then pan will be easier to remove or drop k-member down and have easy access to pan
RE: oil pump??
Thanks guys,I was told by the guy I bought it from that the gauge wentall the way down then he shut it off,he checked oil level and was fine. He says the pump went bad??????????? He started pulling things off the eng. and was going to swap it out for a 90 LX 302 he has on a stand and gave up. Then sold it to me for $500,so I'm up in the air and dont know where to start? do I just swap out motors or try to get this one running again and hope not to do any damage,thanks Bob
jwog666
12-27-2021 08:09 PM
mrappe
09-26-2015 10:16 AM
