spedo cable
RE: spedo cable
I did this about a month ago along with a brand new speedometer. I first take apart my dash and disconnect the speedometer cable from the back of the gauge cluster, remember not to cut the clip that retains it there. Then I jack the car up and pull the pin out that holds the cable into the transmission making sure that I keep track of that pin also. There will be a little bracket that holds the speedo cable on the driver's side fenderwell inside the engine bay, make sure that is taken out. Then, for installation, just do what you did backwards, plug it into the tranny, reconnect it to the bracket in the engine bay, feed it through the firewall and connect it back to the gauge cluster.
RE: spedo cable
well my car doesnt have a cable at all installed.. i have the cable ready.. i just need to no what to do.. its an 87 stang.. can u tell me what to do again and how long it will take hour wise.. thanks
RE: spedo cable
just the cable.. can it be done without me bringing the car in to an auto mechanic.. and how long would this take.. and i just need a precedure of how to do it... can any1 help me out... thanks
RE: spedo cable
ORIGINAL: 1991_5.0_Convertible
If you know what you are doing and keep track of all of your bolts and clips that go into the dash it can be done in an hour to an hour and a half. Bring it over and I can do it lol.
maybe you can do it in 30 minutes.
breaking
10-02-2015 01:27 PM
