Engine backfires and lacks alot of power
Old 07-26-2008, 11:09 PM
Candy Black 94 GT
Candy Black 94 GT's Avatar
Default Engine backfires and lacks alot of power
Hey guy's my 94 gt just recently backfires and lacks alot of power.Any thoughts or ideas that could be causing this problem,before I start to diagnose the problem.Thanks guy's,really appreciate it.
Candy Black 94 GT is offline
Old 07-26-2008, 11:15 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: Engine backfires and lacks alot of power
first thing to do is see if any codes exist after that..make sure the MAF is clean if it has one and make sure fuel pressure is good and make sure there are no engine performance probs such as bad ignition components like bad cap, rotor, or wires
mjr46 is offline
Old 07-27-2008, 03:38 AM
5pointslow91
5pointslow91's Avatar
+1
5pointslow91 is offline
Old 07-27-2008, 07:52 AM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Check your timing along with what Mjr. said.
projectresto83 is offline
Old 09-21-2008, 09:19 PM
Candy Black 94 GT
The MAF was dirty & fuel pressure wasn't right all cleaned up,feel awhole lot of difference.Thanks guy's.
Old 09-21-2008, 09:44 PM
aode08
aode08's Avatar
if you havent, replace those 02 sensors if they are the originals from 1994.
You can rent the socket free at autozone.
aode08 is offline
Old 09-22-2008, 12:59 AM
mstngsule68
mstngsule68's Avatar
check plugs and wires and cap, id just put all new stuff on there....and DOUBLE or TRIPLE check the wiring order, before u do that stuff id check for codes as well.
mstngsule68 is offline
mstngsule68
oh check timing as well.
djbigskrilla
09-20-2022 01:04 AM
ShaneB26154
35
03-04-2021 04:05 AM
Gary Ugarek
63
12-11-2015 02:01 PM
cardsrus1
19
09-15-2015 08:37 AM
Tyoung68
08-25-2015 04:31 AM
Quick Reply: Engine backfires and lacks alot of power
