Camber adjustability on a 89' LX?>>
i just put some lowering springs on my 89' lx and now i have some negative camber, not alot but there is some. Is there any adjustability at all? i know that there are camber kits/plates avaliable but i also thought that there was some adjustments that can be made stock. any help is appreicated
thanks
thanks
RE: Camber adjustability on a 89' LX?>>
you could try to adjust the tie rod ends, just get a tape measure and get the measurements from the drive to passage side front tire, and for the the rear of the front tire, and that shouldput you close to where you want to be.
what about loosening the top strut mount bolts and pushing them in or out, it looks the camber could be adjusted a little that way, i mean there is a slot for the bolts to go towards the engine or towards the fender?
^^^you'll get some that way but your best bet and most correct option would be buy aftermarket caster camber plates to achieve the desired affect and proper one at that too!!
