building a 302 from scratch... questions
hey guys I am new to the forum and im building a 302 from the block up and i just need to know something... with the 302 can i use the block from any year car?? i mean is the block itself the same from the 70's all the way up to the 95 stang gt???? im sorry if this is a beatin topic but i couldnt find the answer... thanks guys!
RE: building a 302 from scratch... questions
why build a 302, not a 331 or a 347?
im not sure as to the answer to your question, but i think only the 80s blocks have roller camshafts, and the holes to mount the dogbone hold down
well yea you could, but the older 302 block on to set up for a roller cam, but you can always have it drilled out for the spider to hold the lifters and stuff in.
to build a 347 i still start with a 302 block right? i know these are such noob questions and you guys are probably laughing, but im just tryin to learn as much as i can.. also what year 302 block am i looking for then? i plan on dropping this motor in either a 87-93 fox or 94-95 gt
ORIGINAL: 94GTPRO5.0
If you want to build a strong engine, rather that be a regular 302, or a stroked 306, 331, or 347, and you have the funds, I'd look into the new Boss 302 block. These blocks are much stronger than the older 302s, and as a result, will take much more of a beating when being geared towards performance. Just another thought for ya.
ORIGINAL: jthorn9
