is it possible to put a t-5 from a turbo coupe in a 5.0
i was wondering if there is anyway of putting a t-5 out of a 88 turbo coupe and it bolting up to the 5.0 if i just get the bellhousing?
iv been told by other people that the input shaft would be changed but i was wonderin if anyone has done it without having to change anything but the bellhouseing?
RE: is it possible to put a t-5 from a turbo coupe in a 5.0
The input shaft is too small and would need to be swapped out. Also, the 2.3 T5 is geared lower than the 5.0
88 2.3 T5 - 3.97 2.34 1.46 1.00 0.79
http://www.mustangevolution.com/forum/t24021/
ORIGINAL: KFC
Its just the same as using a 4 cyl t5 from the stang. Just need the correct pilot bearing. BUT along with being geared a little different they are weaker!!! So don't expect for it to last a long time if you are driving your car like most of us do
ORIGINAL: projectresto83
I'm guessing it's just improper shifting that kills them. Or grabbing & yanking into the next gear attempting to shift as fast as possible without having a shifter with stops.
My brother had a few give out on him during normal sunday driving but he beat on them a few times and had the suspension and tires to hook on the streets. But they are rated for a lower torque rating compared to the v8's.
I ran a non wc t5 from a turbo coupe for a whole racing season in my 87gt. I had well over 100 passes and couple nitrous passes on it. I launched of the rev limiter with slicks and I just couldn't break the thing. The next season I swapped to a t5z for piece of mind and blow it after 20 pases. Go figure. You need a bca bearing part number 202ss or 202ff.
For those that say they don't hold up heres proof:
http://www.youtube.com/watch?v=eCmtPKTl0XE
I'm the blue car, mjr46 and pro50sc were both there that day if there are any doubters.
I vouch for zach too & i don't even know the guy...
I can just see it now... a bunch of people swapping their v8 transmissions for 4 cylinder ones[sm=smiley36.gif]. Honestly I think the 4 cylinder one worked better than my current v8 one... but it was used so it was probably mistreated before me. I know it's mistreated now.
