Need Help Guys !
Alright, we're about to order the stuff to finish the exhaust.
But what flow/starter tubes should we get ? On 5.0 resto they have these, http://www.latemodelrestoration.com/...1&comp=LRS Would they work? Only thing I saw on summit are these, but the pipe has bends so I don't know... http://store.summitracing.com/partde...p;autoview=sku I need some help/input guys. ~Thanks. |
RE: Need Help Guys !
why do you need flowtubes? they usually come WITh your catback
post up everything you are ordering, and we will make sure you dont get anything incorrect |
if your not building your own exhaust and you are ordering a catback set up you don't need flow tubes cause as addermk2 stated they will come with catback...however if you are piecing together a set up and just have bare mufflers than you'd need the flow tubes from summit..not starter tubes;)
Ah alright, we are making our own exhaust. BBK long tubes to BBK O/R H-pipe to dynomax bullets to tail pipes.
then you need the flow tubes^^^^^^^^^;)
Alright thanks, I assume I'll need reducers for the ends of the mufflers to fit into the flow tubes and tail pipes ?
??? Why? Arent your mufflers 2.5"? Arent you doing the whole exhaust 2.5?
Yes, but if I have everything 2.5" it wouldn't be that easy to line everything up perfectly. I figured, weld 2 1/4 reducers on each end, weld one end to the flow tube and put that in the car then clamp the tail pipe to the other reducer. Not a lot of room under that car to be welding exhaust.
Ok guys, so the flow tubes ? Couldn't find any flow tubes, now both links are saying starter tubes, [:@] so are these ones from late model resto the right ones ?
http://www.latemodelrestoration.com/...1&comp=LRS So, those ones right ? Not the ones from summit ? Just want to make sure I get the right thing. |
These are the only flow tubes I found, these are NOT what I need correct ?
http://www.latemodelrestoration.com/...1&comp=LRS |
