Fuel pump wont turn on after swap
I have a 1992 fox 4 cylinder that I swaped to a mass air 5.0. I just hooked everything up and the fuel pump won't kick on. The fuel gauge also says that the tank is full but its empty.
RE: Fuel pump wont turn on after swap
i had this issue aswell BUT i just went carb and wired it hott cause i couldnt figure out what it was i can tell you now people will tell you check the relays under your driver seat well 4 bangers dont have them there i couldnt find out were the 4 banger ones are
