Will I Pass Emissions?
Hey all,
I have to get my stang registered in GA in a few weeks and I have to pass the sniffer test. Right now I have no smog pump and no cats. I'm going to slap on some universal catco converters, plus my EGR Valve, throttle body, EGR Plate, O2 sensors, and IAC are all new with no crappy buildup on them. I'm pretty sure I'll pass, but I was wondering if you all think I should do anything else that would help me pass like back down my fuel pressure or retard my timing a bit. Any other helpful hints would be appreciated. |
RE: Will I Pass Emissions?
sounds like alot of work to pass the test... are you sure you couldn't just give the inspector a "friendly" tip?
make sure you have a 190* thermastat
timing to 8* oil change make sure the tps is right ive heard you can go as low as 30psi on the fuel pressure without damaging it also run some fuel injector cleaner through the car. i prefer stp fuel system cleaner you can run 1-2bottles of rubbing alchohol in a .25 tank of 89 if you dont do that i was told to run 87 octane cause it burns faster |
Well I was replacing all that stuff since I'm doing mods anyway, so it wasn't a big deal. Thanks for the input so far.
