AOD to C-4 Swap HELP!!!!
RE: AOD to C-4 Swap HELP!!!!
ORIGINAL: Skyler5.0
Thats what my car has in it (just found out ). My drive shaft is stock, and i have a rachet b&m shifter (hammer)i think the trans mount may be different but i would have to look. But i don't think it is.
it been a while but i think i used the stock crossmember last time i had a c4 in a mustang. both times i have used one was on a 4banger car so i had to get a yoke/spline and diff driveline, however theres 2 diff belhousings for the c-4 i have both of them, one seems to be for a smaller converter? . also the 2 c4s i have have differant shift levers and i could never find a kit for the one that was outa a 80 mustang
ORIGINAL: mattdel
i think i read somewhere that the holes in the cross member need to be elongated towards the front, but i might be wrong, i stay away from automatics all together.
Ok i just spent some time under my car. I tryed taking pics but its to dark in themto see ,and all it have is a new bushing thats all. if you going to swap you need the stuff from a c4 tq converterect...The shifter i could not tell you!I have an aftermarket but the drive shaft is the stock one ... hope this helps.I will try to get a few of my buds togive me info to help you out, from my other forum.
Matt's 95 Stang
10-05-2015 07:16 AM
