Question
RE: Question
You're sure theres no wiring ? Well it depends on what yo uwant to do. If you want to go fuel injected you'll need the wiring harness/computer from an EFI Car, if carbed you would need a wiring harness from a carbed car or what not so you have all the stuff to hook everything up. Obviously you'd also need a motor since all you have is a trans.
RE: Question
ORIGINAL: XXC
Let's say you have a 1985 Mustang chassis with nothing but a motor and transmission.. No wiring at all, dash, or interior.
What do you need to hook up to get it to run properly?
RE: Question
I wired all that in there.. it runs, but ****ty.
It seems to have a problem only under a load.
Does anyone know about the msd coil?
When the car is on, it's giving out 7 Volts... when I rev it, it goes down to 1 volt, does that sound normall or soemthing wrong?
RE: Question
well first item of bussiness would be to do a load test and make sure alternator is functional after that make sure timing is correct and it's hitting on all cylinders and carb is properly tuned and what size carb it it?? what are mods to engine??
RE: Question
ORIGINAL: Explosive
RE: Question
ORIGINAL: mjr46
Timing should be fine, and it's a Holley 750 Double pump.
The motor was rebuilt from the ground up, .030 over, crank, pistons, ect.
RE: Question
since you don't have alt hooked up voltage will be slowly dropping constantly and can affect all sorts of things expecially the ignition system and a 750 will choke that motor out..most likely the jetting it way to rich....650 max and more so your build is suited to a 600
