f$$$in codes help me out
RE: f$$$in codes help me out
ORIGINAL: jtmustang
so what are your suggestions on those 2 codes joel?
and so what should i set the tps at then...?
but back it down a bit, because there is always a chance that while the car is running... your .999v is reading over 1v
check to see if you have the ground hooked up on the back of the intake/ headand make surethe wire is not frayed that is gone to it. it is one one of the main ECM grounds it is on the rear driver side of the intakeor head.. whats that ground called ? HGO ground I think.I know they will go wild if it is not hooked up orthe wire is bad to it. As far as your TPS I set mine around .90 for a NA car. I have set them on every car I have owned and tuned on for othersand it has made a difference.
i know for sure the ground is good back there and hooked up.
and do u think all the idle problems and breakin up is just because of the iac not set right?
and why when i push the clutch in does it want to die suddenly , but it will idle when i gently drive it?
and so i guess i should replace the sensor in the tranny
and the neutral safety switch right for 67?
lincolnshibuya
12-08-2015 04:37 PM
