460 in a fox
460 in a fox
ok so i have a chance to get a 460ci w a heavy duty c6. i want to drop this into a classic but cant find one so im thinkng about going with a foxbody. my concern is should i do it or not??? yes i no bout the motormounts and going to beef up the rear end. what bought clearance issues thinkng of going with headers from summit racing. also going to get a new k member probably from upr or summit racing.
RE: 460 in a fox
cornering ability destoryed? thats wat i havent tought about it will be a street driven car not daily driven but damn it shell be burning rubber each week. so i basiacly cant go fast on corners or wat.
RE: 460 in a fox
my neighbor has a 460 in his fox....this thing is a monster for TQ. 1/8 mile its faster than hell, quarter mile isnt as fast as you'd think. he has a 460 and i think he has, aluminum heads, single plane intake, eddy carb, 430 or 460 gears...cant rememeber, auto tranny, really tall slicks, full roll cage, no interior 3" exhaust, 12:1 compression, nitrous....i dont know much more about it really but i've riddin in it...its fast but he said its set up for 1/8 and not quarter so he says its not fast in the quarter.
RE: 460 in a fox
460 in a fox is pretty easy to do. You can get over 550 cubes out of a stock 460 block with no clearancing needed. BTW, a car set up for 1/8th mile racing will be running a real steep gear, so it would be wound to high for 1/4 mile.
RE: 460 in a fox
The conversion pieces are about $800
Add a 31 Spline Rear Axles
Torque Box Plates Welded In
Aftermarket Control Arms<Upper and lower
Racing Drive Shaft
Bigger Brakes and Rotors
Larger Tires
Upgraded Suspension and Chassis
Cornering problemscan be defeated by having caster/camber plates, lowering and adjustable struts, tubular K-Member and heavy duty engine mounts.
Your building a beast, and I dont know if your ready for all this torque, my buddy had one stroked out in the 500's; in the 9's ALL MOTOR 4 foot WHEELIES.
I guarantee you if you just drop this motor in, youll be very upset you didnt upgrade those parts, its heavy and FULL OF ALUMINUM TWISTINGTORQUE.
Racing Drive Shaft
Larger Tires
RE: 460 in a fox
ORIGINAL: FivePointOhh
