these questions may sound dumb to you...
... but ive only built an engine once and its been more than a year ago can anyone tell me every gasket i need to put RTV on from the pistons up? and is there a website that will give me all the torque specs?
RE: these questions may sound dumb to you...
intake gasket corners and front and back of intake instead of gaskets, and then the normal water pump,timing cover...that should be it.. i use the reuseable rubber/metal valve cover gaskets so no rtv there..
luckily i was able to figure out the problem without taking the water pump off so i dont need to worry about that.. and what about the exhaust manifold? and what do you mean instead of gaskets?
yo I got you back on this... I think
Take a look at this.....
http://www.moddedmustangs.com/forums...fications.html
If the link didn't bring you there go to modded mustangs .com and then go to forums and then go to 5.0 and at the top there will be a sticky called 5.0 engine tech and specs
