slight ticking and popping noise from intake?
any1s intake ever make popping noises? i can hear a slight ticking from that area, and also a crackling and popping. car seems to slightly pop and backfire from exhaust as well.
what could be the cause?
Ticking noise might be your injectors, maybe lifters, but without hearing it can't really help you. Injectors is a normal noise, they should make noise, if they don't they're not working. Lifters shouldn't.
For the popping and backfiring, check your timing
oh ok, i did install new injectors so i hope thats it. i checked the timing and its at about 17 degrees...could that be the reason?
while driving i can hear a slight ticking coming it sounds like from the driver side, im wondering if it might be a header leak
AmericanMuscle4.6GT
11-10-2015 02:06 PM
