How Much Oil ?
How Much Oil ?
Alright I've got a question, we put 5 quarts into our motor, but we have an aftermarket dipstick, and it's reading WAY overfilled. Now what I've heard is 5-6 quarts of oil for the 302. So whats a good amount, I know that dipstick has got to be off because there is no way 5 qts is that overfilled. We bought 6 qts, how much should I put in the motor ?
RE: How Much Oil ?
It's 5 quarts. Did you make sure and undo both drain plugs when draining the old oil. It's a double sump oil pan so if you only did one plug there was probably still a quart or two of oil left.
RE: How Much Oil ?
ORIGINAL: Explosive
Yea, we went to the speedshop tonight and they also said just 5, they reccomended pulling the stick, marking where 5 would be and shortening it ?
