supercharger or turbo charger?
RE: supercharger or turbo charger?
Depends on your goals and driving habits. Turbos make more power pound for pound of boost, but sometimes lag in the lower rpms. SCs are tried and true, used in professional dragracing. Turbo you have to change out your exhaust system and it adds a lot of under hood temp. Ive got a 95 GT Im building a new engine for with GT40 heads and a Steeda 19, Im going with a S/C when my birthday comes around
This question has been asked by hundreds and I'm sure there are just as many threads about it. Just do a search, although you will never find an answer to which is better because they both have their ups and downs and people to support on bith sides.
My pick, turbo. I've worked with turbos for years and IMO would consider myslef an expert on them. I install, fab, and rebuild them for a number of different applications and just overall like the feel of a turbo over a SC.
ORIGINAL: USMC1775
I thought I deleted that part... my bad, I realized after I wrote it down that Ive seen more turbo'd cars at the drags now than S/Cs when watching the private and weekend warriors.
Like you said, its a 2 sided battle, and Im for S/C.
Although I wouldnt deny a turbo
Turbo FTW...even though its a little more work.
An internal combustion engine is only about 33% effiecient, meaning 33% of a/f is used to make power, 33% is lost in heat and 33% lost in the exhaust. With a turbo you are using a portion of that heat and exhaust you would otherwise be wasting to make more effecient power for your vehicle.
Unlike a supercharger which has a parasitic draw on the engine to turn the compressor, still pushing more air into the cylinder to yeild more power, but, not as efficiently.
You can have very efficient power across the board with turbos if you size it properly, usually a twin set up will aid in this than one large turbo. However, turbo lag can be experienced with larger compressor wheels.
My 2 cents:
Get an older Paxton (sn). It is much less involved and very reliable. No tapping into the oil pan either (self contained fluid). I've got one on my '86. It also builds boost faster than other centri. blowers and builds boost much faster than a turbo.
Having a lot of fun with the car I am getting over 19mpg. I may hit over 20mpg (combined) if I can stay off the throttle some (but who wants to do that?) and drive home on the expressway more.
With a turbo you will probably have to add an intercooler and all. With the higher boost from the turbo you will loose reliability (blown head gaskets and all). From what I can tell the turbo will get you more hp, but for the same amount of money you can do other things to the supercharger or engine and easily have better hp.......of course this is an opinion from a guy on a budget.
