Help with a code pulled this afternoon
After working on my car during the day I ran codes to make sure everything was ok... I pulled a 542 which is "542 - Fuel pump secondary circuit failure: PCM to ground"
I didn't touch anything to do with the computer or even the rear of the car let alone the fuel pump.... Anyway the car wont start and I need some help!
Thanks
Thanks
RE: Engine code help that should be so easy....
what did you do to the car that day?. i put a clutch cable in and some how unhooked the fuel wire under the dash. well the plug is way up on the inside of the drivers kick panel.
I replaced my intake/head gaskets and a tb gasket... I didn't stray from the project either that's why I don't understand how this could have happened...
Another thing I noticed is that the battery is lit up in my dash which makes sense but maybe that helps..
Thanks for the help guys but i got it. A vacuum hose under the manifold without a clamp came off... While on topic though why would this cause me that code to come up?
