Vacuum hose schematic?
Old 08-12-2008, 02:55 PM
Five0hFox
Five0hFox's Avatar
Default Vacuum hose schematic?
Does anyone have anything that shows where all the vacuum hoses go? I've got some broken hoses from the a/c and I don't know where they all go and yea. Just wanna check make sure I get them right.
Five0hFox is offline
Old 08-12-2008, 03:21 PM
Joel5.0
Joel5.0's Avatar
Joel5.0 is offline
Old 08-12-2008, 09:49 PM
Hung Like a Stang
Hung Like a Stang's Avatar
I was needing the same thing, so I'm quite glad you asked ksranger!
I was wondering if anyone had a picture of the map sensor hose and where it goes.
and what is this vacuum check valve?
Hung Like a Stang is offline
Old 08-14-2008, 12:45 AM
Hung Like a Stang
bump bump
Old 08-14-2008, 06:34 AM
Joel5.0
Joel5.0's Avatar
Vacuum check valve:
If your setup is speed density, the MAP port is under the upper intake at the back. If your setup is a MAF setup, no vacuum line goes connected to the MAP or BP sensor now. The hose for the MAP would go to the port tagged as "capped off" below.
Joel5.0 is offline
mrtrodonet
09-19-2020 03:12 PM
baddog671
07-26-2016 01:20 PM
Demodulates
09-18-2015 11:14 AM
LivingInThePast
09-16-2015 12:20 PM
TfcCDR
09-14-2015 12:08 PM
Quick Reply: Vacuum hose schematic?
