new car problem...
Old 08-12-2008, 10:28 PM
dv3
dv3's Avatar
Default new car problem...
im looking into get a red 25th anniversary stang for $2250 (original owner) ....problem is the guy says it doesn't run after about an hour in hot weather ....he said it was the fuel pump .....is there anything else i should be looking for that would cause this?
dv3 is offline
Old 08-12-2008, 10:34 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
it could be an ignition issue..when prob occurs you'll need to check for lack of spark or fuel
mjr46 is offline
Old 08-12-2008, 10:37 PM
dv3
dv3's Avatar
easiest way to do that .....fuel pressure gauge?....what should the pressure be?
dv3 is offline
Old 08-12-2008, 10:46 PM
mjr46
mjr46's Avatar
carry a can of spray start..when it dies spray some in TB if it fires up then dies = fuel..if not carry an inline spark checker or used spark plug then while cranking if using old spark plug pull a wire and attach to used plug and ground it and crank engine as you do so and look for spark
mjr46 is offline
Old 08-13-2008, 09:13 AM
dv3
dv3's Avatar
Default re
if it was the ignition how does that compare in price to the fuel
pump?
dv3 is offline
djbigskrilla
09-20-2022 01:04 AM
chain
08-17-2015 08:52 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
ccwebb
08-11-2015 06:47 PM
Quick Reply: new car problem...
