Problems after 130 amp alternator upgrade.
I am having a problem with charging on my 91 Mustang GT. The problem started after I took it to an electromechanic because my old stock alternator died, I decided to buy the 1995 Mustang GT 5.0 alternator and have the mechanic install it. The new alternator worked fine for about a week but now the voltage drops when the car is at about 900 RPM my RPM is steady and the charging problem only happens when the car is at idle.
I talked to the same mechanic about the problem and he said my RPM might be to low but I don't think that's the problem because from what I have read a normal RPM at idle should be at about 900RPM for a stock 91 GT like mine.
The mechanic did use the pulley that came with the new alternator. I am thinking he should have used the pulley from the stock alternator.
Any suggestions?
Any suggestions?
was this with any accessories on or not? the 3g alts have to be energized to produce charge, and with wrong speed, at dead idle it wont charge.. could try changing the pullies out.. does you car have underdrives? mine at idle... with all accessories (being a lincoln has more draw) lights, wipers, stereo, amp, fan, ect all on will discharge but at 1000-1100 rpm it works fine.. but idle energized 3g only puts out 65amp usually, could try bumping your idle screw up a bit and see what rpm it does actually start charging at.
My voltage drops when the car is at idle even with no accessories on. I compared the stock pullie to the one that came with the new alternator and they looked the same, that's why I decided to use the new one. My car has no underdrive pullies. The mechanic did change the wiring to a better one.
I no longer have the old stock pullie for the alternator, but I will try to find one at a junk yard to se if that fixes the problem.
Thank you for your help.
Golfsito
10-06-2015 11:02 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
M3hunter
09-05-2015 03:42 PM
