THE BEST HEADS....
RE: THE BEST HEADS....
YATES
Ford Motorsport Yates heads have are designed for a max effort racing engine. There are currently 3 different style castings for a Yates head:
C3,C3L,C35 CONVENTIONAL YATES CYLINDER HEAD. STANDARD YATES CASTING
C3H SIMILAR TO STANDARD C3 CASTING BUT HAS RAISED INTAKE RUNNERS WITH STRAIGHT IN INTAKE BOLT PATTERN
SC1 ALL NEW YATES CASTINGS WITH RAISED INTAKE & EXHAUST PORTS. EXTRA MATERIAL FOR HIGHER FLOWING PORT DESIGNS
All of our Yates cylinder heads are prepared for your application. Our C3 castings flow up to 390 cfm on the intake and 275 cfm on the exhaust. Our C3H castings flow up to 400 cfm on the intake and 275 cfm on the exhaust. Our SC1 castings flow up to 420 cfm on the intake and 290 cfm on the exhaust. All SC1 and C3H castings are machined for Jesel or T & D 1 piece stand rocker arms, and have a spread guide location which will accept 2.20 X 1.60 valves. We have done more sets of Yates heads for drag racing than any other cylinder shop. We can modify your existing Yates heads new or used, call us for quote. If you have a set of Nascar take off Yates heads we can convert them for use on a drag race engine, which usually consist of custom valvejob, porting, triple springs, and titanium retainers and locks. All 3 versions below feature fully CNC ported castings, Del West titanium valves, Manley Nextek triple springs, titanium retainers, and locks. We have almost 900hp naturally aspirated and over 2000 hp on our turbocharger and supercharged engines with the below Yates heads.
Yates C3 $6895
Yates C3H $7295
Yates SC1 $8295
Yates C3 $6895
Yates C3H $7295
Yates SC1 $8295
ORIGINAL: vfast
YATES
Yates C3 $6895
Yates C3H $7295
Yates SC1 $8295
YATES
Yates C3 $6895
Yates C3H $7295
Yates SC1 $8295
