hey guys need a little help with a newish car
Ok my girl got a 94 gt yesterday and it has a few problems here and there, as to be expected, but the one semi-major one that needs to be fixed is the shifter in it. (it's an auto) When its in park it's hard as hell to push it in I sometimes have to use two hands and Im a fairly in shape fella so its really hard for her to get it in gear so at the preasent i think she is leaving in neutral with the break on not the best idea all the time. Its fine once its out of park so I'm thinking possibly something with the brake sensor or something? anyone give any advice?
could be the spring mechanism inside the button acting up. you should find a couple small screws on the back of the handle to open it up. take the spring crap out, try to remember how it came out, and work it manually without the button. see if its easier.
when mine was still an auto..i had the same problem..i would be like standing on the brake and it would finally give in...didnt realize at the same time i didnt have brake lights..turns out the wires had corroded and come out of the brake switch on the pedal..fixed the wires n hooked up the switch and brake lights work..altho once i had done this i also was no longer an automatic so i guess i cant guarentee that it would have fixed the shifter problem..but my guess is it would have...its worth a look under the dash tho ..easy to spot..
all right where about were the wires located under the dash? and i also found out that if i turn the key a bit forward not all the way to the on position but just before then it's easy/normal to push the button put it in neutral and procede to start the car and put it in gear anything ringing a bell with anyone?
If it is not key related/Brake pedal related you may want to check the Manual position sensor. It is located under the car on the drivers side of the tranny. It is where the shifter cable goes to. there are alignment slots make sure they are aligned and that the cable isn't getting hung up on anything.
i'll check a few things out tommorow once it gets light out again and i get some free time thanks guys
and just for S&G's heres some pics i like the interior but ive never seen white and black personally sorry for teh quality i dont have my camera i'll get more later for you guys
Soldier GT
12
08-20-2015 09:42 AM
Soldier GT
08-12-2015 03:46 PM
