hesitation at slight throttle
i am about to give up on this damn car, hell i could have had my old ford truck in showroom condition by now... i had no voltage going to passenger 02 sensor so i replaced it, now i get code 42....how can code 42 show up with a brand new 02 sensor?????? no matter what i do car wants to run rich... i have tried everything....fuel pressure is fine, still get code 84, 33, which i have already given up on, i think it is just embedded in my computer.
that i dont think is going to cause my massive hesitation at slight throttle, i think it is the fact that she is running rich....now what else could that problem be...fuel pressure fine, new 02 sensors, timing is fine i think, unless i am a tooth off which i highly doubt
check the ground for the injectors on the back of the heads
i moved my ground to the firewall because it kept coming off
i also get the hesitation, check my thread and see if u got similar symptons
i port matched my stock intake myself, is there any way maybe that messed something up cause i did not do it right, i matched it to the gasket and no more the best that i could, i feel i could have ported it out more
As for code 84 and 33 you probably already know those are Evap and EGR system codes as in vacuum and sensor related. Not fuel.
If you fix the code 42 you may also get rid of the other two.
