Rich after mass air conversion
RE: Rich after mass air conversion
ORIGINAL: 95stanggts
How do you reset the computer. I have a hand held reader but it does not clear codes.
Here ya go:
1. Clear the EEC-IV's idle memory by disconnecting the battery for 20+ minutes.
2. Disconnect the Idle air bypass solonoid
3. Reconnect battery
4. Start engine and set idle speed to desired RPM with stop screw on throttle body (900 rpm works great with E303 or larger cam)
5. Turn off engine and reconnect the air bypass solenoid - *Optional -- set TPS to 0.90 - 0.95 volts (Do not exceed 1.0 volts MAKE SURE!) Use a digital volt meter!
6. Start engine and let it idle for 2 minutes with no accessories on.
7. Turn off engine for two minutes
8. Start engine again and run for 2 minutes with every accessory turned on.
9. Turn engine off again.
Your computer should have now re-learned the new idle settings. This procedure assumes that you have a clean IAB valve. If it is carboned up then you may need to remove it and clean it with carburetor cleaner.
ORIGINAL: sc94gt
Here ya go:
Here ya go:
daltron
04-28-2016 08:10 PM
