Stock Tach Doesn't work
I converted to carb. I know which wire goes to the -side of the coil but the tach still doesn't work.
I follwed jason fletchers write up and the dark green/yellow wire is supposed to run the stock tach.
When I connect this wire noting happens. Is there another connection Im missing?
I know theres guys on here who have done the swap before.
on my 92 the wire color is tan with a yellow stripe..no sure if the colors change throughout the years , you need a wiring diagram for your year and see if your on the correct wire the website may be wrong on the color wire
I do have that color wire. But it doesn't do anything. When I am turning the car over the tach goes the opposite way until it starts. I could always put in a aftermarket tach but I don't want the big clock looking thing mounted on my dash.
According to my manual it should be the green/yellow wire. I think up until 91 they were all the same.
I thought about that too. I have a Haynes manual. The diagram is ok but not the greatest. In theory I should just be able to tap into the green/yellow wire on back of tach and run it to the coil. Correct?
