lost 4 miles an hour on 1/4 over winter
My car was in my garage all winter took it out to the track usually hitting about 97 98 m.p.h but only hitting about 94 95 m.p.h what could be the problem
RE: lost 4 miles an hour on 1/4 over winter
when i raced it was a cool day like the end of the year last year when. i run the best when its cool out it felt like it was all right i was hoking well same as last year just m.p.h was down when i ran that day it was no differnet than last year but if you think anything different let me know but im going out tomarrow again and i will let you know thanks
When you go to the track ask one of the bracket guys what the D/A is (make sure you do it when they are not busy). D/A will tell how "good" the air is, the lower the D/A the more power your car will make. You can figuer out D/A if you have a barometer, a thermomerter and a hydrometer. Basicly what you want is high barometric pressure, low tempurature and low humidity. You probably had very good air at the end of last year, my car varys as much as 3 or 4 mph and .3 tenths depending on the D/A.
went back out yesterday still ran a consistent 14.4 at 94 still 4 miles an hour off anf 4 tenths off cool nit and a tail went all night it was the same
sorry thats supposed to say cool night and tail wind we adjusted my timing and everything from being 14 all last year and even went up 15,16,and 17, and it was the same all night 14.4. at 94 if anybody know why please tell me because it is reall starting to make me mad i have never ran this slow i have all ways been consistant running 14.0 at around 98 every day even if it was hot as hell out i would still run 14.0 14.1 and always 97 98
Hmmm, maybe you should start with the basics, check your plugs,wires, timing and air filter, check the valve lash and make sure that it is not running lean or rich. After that I don't know what to say, how many miles are on it? Is there any chance you hurt the motor?
it has 64 thousand original miles last race of the year it was fine set all winter then first race it was just sucky i changed the sparkplugs befor i ran yesterday one of my friends said when i bought the car it could of had a chip in it and the chip could of burnt out if that is possible do you know where the chip could be placed at
