bad fuel leak
bad fuel leak
yay more problems..
i ended up cutting a hole in my hood (just the inside) to fit my struts and while doing that i could smell fuel.
i figured one of the vapor lines came off or cracked.. no biggy. boy was i wrong. im assuming the return-line is leaking above the right front wheel right where it meets the rubber down hose.
i assume its the return line because the engine runs smooth. (does not hesitate anymore either..).
my friend says theres no way to patch it.. gotta do the whole thing? i hope hes wrong lol
theres a little metal strap holding them to the frame, like the brake lines.
the 2 lines run parallel next to the frame inside the wheel well and then are routed under the frame, where they are strapped. it leaks right where the strap is.
