Getting a little front vibrations
I'm getting vibrations that I can feel in the steering wheel and it vibrates the entire dash of the car only between 20-30mph. it's smooth below 20 and smooth above 30. If I'm breaking from say .... 60+, it breaks nice and smooth until it gets to about 30, then the vibrations start and it goes away once the car slows under 20.
Any suggestions as to what this can be?
I highly doubt a vibration at 25 mph is a wheel balance problem. Especially if it goes away after 30. For the sake of simplicity it wouldn't hurt to start there though.
Before you remove the tires. Lift the car up. Spin the front tires with your hands. Note the tread runout. It should be less than 0.040".
Carefully inspect the sidewall, high spots in the tread and low spots from wheel lock up during braking.
