how...timing???
RE: how...timing???
well, does your engine already run? if it already runs then you do not need to find top dead center, that is the first step when installing the distributor without knowing where it came from :P you just need to hook up your timing light and do what these guys have already told you.
RE: how...timing???
the spout
RE: how...timing???
ORIGINAL: JJM1173
After your done do you plug the spout in again and what would be a good setting for the timing, Does it matter if you have changed the cam and the heads sry if I'm asking stupid questions just want to get it right,
the spout
