hey guys i need help with a engine question
Hey,
I have a 95 5.0, It idles fine but when you try to give it gas it will go up to about 1500 rpm's then if you try giving it gas it wants to shut off. Is it the o2 sensors giving it too much air or something? Or could it be the Tps sensor? ANy help would be greatly appreciated. Im ready to drive it again!!!!!
I drove it to the mall and while crusing up to the stop sign it started idling funny and when i tried giving it gas it would shut off. Then i kept trying to crank it and sometimes it would run a little and as soon as i gave it gas it died. I a gallon gas in it thinkin maybe the guage was wrong and then i went to the gas station and filled it up. The guage was right but it never did it again until now. I bought a new fuel filter thinking maybe theres trash in it that blocks it up sometimes? but i havent put it on yet
but like i said it idles fine now and it will let u get up to 1500 rpms before it wants to shut off..before u couldnt hit the gas at all and it wouldnt idle 3/4 of the time
If the fuel pressure is in the low side (~22 - 27 PSI), the engine will start and idle, once load is applied it will have the symptom you describe. You need to check fuel pressure to ID or discard this possibility from the possible causes list.. LUK
Soldier GT
08-12-2015 03:46 PM
